Creates a VRRP instance on the switch.
| vlan_name |
Specifies the name of a VRRP VLAN. |
| vlan_list | VLAN list (1–4,094). |
| vridval |
Specifies a VRID for the VRRP instance. The value can be in the range of 1‑255. |
| vrid_list | List of virtual router IDs (1–255). |
N/A.
VRRP Router IDs can be used across multiple VLANs. You can create multiple VRRP routers on different VLANs. VRRP router IDs need not be unique to a specific VLAN.
The total number of supported VRRP router instances is dependent on the switch hardware. For more information, see the ExtremeXOS Release Notes.
Before configuring any VRRP router parameters, you must first create the VRRP instance on the switch. If you define VRRP parameters before creating the VRRP, you might see an error similar to the following:
Error: VRRP VR for vlan vrrp1, vrid 1 does not exist. Please create the VRRP VR before assigning parameters. Configuration failed on backup MSM, command execution aborted!
If this happens, create the VRRP instance and then configure its parameters.
The following command creates a VRRP router on VLAN vrrp-1, with a VRRP router ID of 1:
create vrrp vlan vrrp-1 vrid 1
VLAN and VR list options added in ExtremeXOS 22.3.
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the VRRP feature, see the Switch Engine v33.1.1 Licensing Guide document.
